Recell or Bluetooth GeoTronics
(@laxbobcatsurveyor)
Trusted Member Registered
I have a TopCon 815A with Satteline 3Asd's.?ÿ The batteries need to be recelled as they dont hold charges.?ÿ Does anyone know who performs that work, and if its worth it or should I just get the bluetooth setup from GeoTronics.?ÿ I run SurvCE, but have Survey Pro as well.?ÿ I just need it to work with those.
Posted : 05/10/2018 5:31 pm
(@russ455)
Estimable Member Registered
If you as happy with the radio rangŽ?, cables arŽ? good, and you dont mind the extra ?ÿweight, ?ÿthen stick with the rugged reliable.
one bt radio at the gun is ok but if you also need one at the collector, ?ÿIt may not last through ?ÿrough field work
any survey sup?y house should be able to resell those batteries
Posted : 06/10/2018 4:40 am
Illustrious Member Registered
I am a Big Fan of the Bluetooth by Deatonƒ??s GeoTronics.
Posted : 06/10/2018 8:56 am
(@mattsib79)
Reputable Member Registered
Recently bought the Geoteonics Bluetooth radios and am very happy with them.?ÿ
Posted : 06/10/2018 3:11 pm
Share:
