Promark 2 unable to fix
(@solosurvey)
Anyone know of a source for firmware for Promark 2? I have a receiver that cycles between fix and float and cannot resolve a baseline, recent development after many years of solid service.
Posted : January 8, 2014 5:16 pm
This is the only link I know of
PM2 LINK
Posted : January 8, 2014 6:14 pm
(@mark-silver)
You can also get the latest (but not new) from:
[ PM2 Stuff ]
When you say 'cycles between fix and float', I get confused because I don't think that the PM2 ever did RTK. Are you sure you don't actually have a ProMark 3?
Mark
Posted : January 9, 2014 6:51 am
(@solosurvey)
Receiver is a PM2. When I look at SV status, the bars fill, drop, then shift between SV's. I've found and updated firmware, will field test this afternoon.
Posted : January 9, 2014 9:10 am
(@solosurvey)
Thank you, downloaded and upgraded receivers, will field test this PM.
Posted : January 9, 2014 9:12 am
(@mark-silver)
I think that a CODE 32 will get you just as far as a firmware reload. (Unless it is running old firmware.)
M
Posted : January 9, 2014 9:23 am
(@stacy-carroll)
Tim,
I second the Code 32. One of mine did almost the same thing. Code 32 got it up and running again. Give me a call if you can't get it going.
Posted : January 9, 2014 11:44 am
(@solosurvey)
Thanks Stacy. After update, and initializing, all receivers are working.
Posted : January 9, 2014 3:41 pm
(@stacy-carroll)
Tim, just remember the next time one of your PM2s gets stubborn, code 32 will usually do the trick without having to reinstall the firmware.
Posted : January 10, 2014 5:42 am
