Haven't seen a pincushion in a very long time. Recovered a 3/4" IP, a 1/2" IR, and a broken 4"x4" CM.
Posted : 31/01/2018 6:31 pm
All I see is pink paint all over ever thang?ÿ
Posted : 31/01/2018 7:07 pm
OMG, pink vomit and goat stakes?ÿ ?
Posted : 31/01/2018 11:58 pm
The pipe and the pin can be lumped together as one item. I'm not really seeing the concrete monument.
I'm thinking about using spikes and pie-pans.?ÿ The big ones.?ÿ If you wing around and hit the pan, you're good.?ÿ Your property line is now 9 inches wide.
Posted : 01/02/2018 9:01 am
The south side of the monument is missing. The monument rebar is bent to the northwest and is quite bright because of the sun.
Posted : 03/02/2018 3:08 am
