parani radio with trimble 5600?
 SWAG
(@swag)
Will the paranis work with a 5600 and a TSC2 running access? If so how well?
Posted : 12/03/2015 7:53 am
(@lifeisbetterwhenyousurf)
This subject has been covered in the past, you can search for past posts and see what has been covered.
As far as my experience, I have only been able to run the Parani/5600 with Survey Pro software. I haven't been able to get the set-up to work with Access or Survey Controller.
In your efforts, ensure you use a null modem adapter between the instrument and the Parani.
Posted : 12/03/2015 12:18 pm
(@pinost)
HI BY USING TRIMBLE 5600 WITH SURVEY PRO
USING THE RMT 606 TARGET PRISM CONSTANT VALUE WRITTEN ON THE RMT= 2MM
THIS VALUE SHPULD BE ENTERRED IN SURVEY PRO AS 2.0MM OR -2.0MM ?
Posted : 27/04/2015 1:07 am
(@pinost)
3
Posted : 27/04/2015 1:08 am
(@norm-larson)
I have tried a couple of times now with Survey Controller and have had no luck, so, thanks for that post. I was trying to get our TSC2's to work before switching to new data collection, so, if we ever needed it we had a back up. I even printed a new hat and accessories for the TSC2, LOL. This is a direct link to where I first received tham https://surveyorconnect.com/index.php?mode=thread&id=241500#p313948 Time to move to the new controllers I guess.
Posted : 27/04/2015 8:18 am
(@norm-larson)
Just too correct my last post, I was able to get almost full function out of Survey Controller on a TSC2. An electrical spike subsequently took out all of our TSC2's so I have dropped any further experimentation. It does work though
Posted : 09/08/2015 3:03 pm
