Why would you have to set a rebar somewhere around it? It's sticking up a foot! If you can't find that thing, you have bigger problems. Tie some flagging around it and call it a day.
Nice find by the way.
mattharnett, post: 433795, member: 6458 wrote: Why would you have to set a rebar somewhere around it? It's sticking up a foot! If you can't find that thing, you have bigger problems. Tie some flagging around it and call it a day.
Painting it on flo pink is the correct practice.
Dave Karoly, post: 433801, member: 94 wrote: ?
Concrete yes. Sandstone maybe. Granite? Not me Hose B.
It's already pink (feldspar).
Brian Allen, post: 433741, member: 1333 wrote: Or, you drill and epoxy a dimpled disc into the top of it so you can record a measurement to a precise mm.
That's too d@mn much work; just do it in CAD
Stone Fnd
0.05' N
0.07' W
Didja set a centerpoint on it? maybe a lead plug and tack?
looks like it's off a couple tenths
The first photograph is an iron bar. The other metal object (bent) may have been set as a witness. I was digging to find the spot where it enters the ground when I encountered the original monument.
The second photograph is of a granite stone with a drill hole characteristic of those set by the surveyor. You can tell how good it is by how little an area I had to dig to get to this one.
Finally, the third photograph is a concrete bound that was just below the surface. Needless to say, but, I was very happy to find these.
I find these all day long and yes sometimes there is a cross in the middle and 4 drill holes sprinkled around the top as well from years of 'calculations'
Sent from my SM-G955U using Tapatalk
Those 2 words were stuck in my head last Friday. Show up at a 15 ac site to recon for a boundary survey. While van side finishing my coffee & organizing plans, an abutter comes over and we chat for a few. Turns out he used to work on field crews for various firms in the area & seems to know his chops.
Fast forward a few hours and I am poking around his yard looking for some pipes, he comes out and points me in the right direction "its about 15' off that barn corner, but your not going to find the pipe. It was sticking up 4" & I kept hitting it with the mower, so I pulled it and set an rebar & cap flush" I just stood there waiting for the punch line.
