OPUS Projects -- TRI Network Design
It's been awhile since I last used OPUS Projects, and I noticed today that the TRI style of session processing is no longer an available option.?ÿ The User Guide still discusses it, but the guide has a 2015 publication date.?ÿ I know the TRI style has some limitations, and probably doesn't make any significant difference in final positions, but I like it because it lets me see the effect of direct connections between multiple CORS and my unconstrained marks.
I thought I could effectively replicate the TRI style as a User style by designating my unconstrained marks as hubs, but that didn't work -- I still get single-CORS connections as shown (CORS are the circled triangles, green dots are my points).
Thoughts?
t
Posted : March 24, 2020 9:04 pm
(@gene-kooper)
Since you want to see the individual effects of each of the CORS stations on your stations, you can run three simulations where each of your stations is the sole hub and the other two are turned off.
Posted : March 24, 2020 11:31 pm
(@spmpls)
Jim,
I recommend you contact Dan Gillins at NGS. If there is a way to do it, he will know.
daniel.gillins@noaa.gov
Posted : March 25, 2020 6:09 am
