Is anybody else having problems printing OPUS results reports? All I get are two blank sheets with some kind of error statement. Tried to print on two different printers and make a .PDF file with the same results.
Maybe try: Ctrl A, Ctrl C.?ÿ Open Notepad.?ÿ Ctrl V.?ÿ File>Print?
That is what I do.
Copy and paste the email contents into a text file. It is a classic 80 character per line output so it formats good in Notepad. I store that in the project folder on the server.
That is what I do.
Ditto!
I always get the extended output report, so after I save the entire file, I cut the top 50 lines (or so) off the top, and print it/them out. This page goes in the manila file folder, and I then use the whole text file for adjustment purposes (I wrote a BASIC program that extracts the G-File data from the extended report).
It works for me,
right most of the NGS output is a model made before catalytic converters so they run good on regular Notepad gas.
Right on Dave,
I use NOTEPAD for all sorts of things, including RINEX files, as well as those[sometimes] godawful spreadsheet created .csv files, although the really stinky ones require some BASIC intervention.
