Opus help
(@kalston)
I have a tps file I cant get uploaded to opus. It is about 6 hrs. and I had changed the static rate from 30 seconds to 15 seconds so it is a rather large file. Could I bother someone to run it through for me. My browser seems to time out. Thanks
Posted : September 13, 2012 6:19 pm
(@moe-shetty)
send it over, i will run it
Posted : September 14, 2012 3:42 am
(@moe-shetty)
your email had no attached RINEX. that is what i was expecting
Posted : September 14, 2012 7:41 am
(@geeoddmike)
Howdy,
Convert your TPS file to RINEX using the utility ar: http://www.topconpositioning.com/products/software/updaters-and-utilities/utilities
Find and download the appropriate version of UNAVCO program "teqc."
Read the teqc documentation and examples.
Run the decimate routine on the file to reduce collection interval from 15-seconds to 30-seconds using -O.dec[imate]
This is from documentation: " ...modulo decimation of OBS epochs to # time units (seconds by default); -O.dec 30 or -O.dec 30s or -O.dec .5m results in epochs nominally at 00 and 30 seconds being output; millisecond jumps should be accounted for automatically."
I imagine the same problem you had uploading the file to OPUS exists when trying to send the large file via email.
Links for teqc:
http://facility.unavco.org/software/teqc/teqc.html
http://facility.unavco.org/software/teqc/tutorial.html
HTH,
DMM
Posted : September 14, 2012 1:07 pm
