Noting a greater number of antenna problems/questions I propose an open dialogue.
Based on my readings the recent CORS readjustment was accomplished using absolute antenna models, Yes or No?
I believe a GPS receiver collects and stores observations without any consideration of the antenna model, Yes or No?
I believe proprietary GPS data files are converted to RINEX and vise versa without any consideration of the antenna model, Yes or No?
I believe antenna models should be (but are not required) for differential solutions, Yes or No?
I believe antenna models are required for precise differential solutions, Yes or No?
I believe using all relative antenna models in a solution can result in precise differential solutions, Yes or No?
I believe using all absolute antenna models in a solution can result in precise differential solutions, Yes or No?
I believe using a mix of relative and absolute antenna models in a solution cannot result in precise differential solutions, Yes or No?
Following this I will render general questions regarding ARPs, phase ceneters and antenna heights.
