NGS datasheets for reported destroyed marks.
 vern
(@vern)
>From http://www.ngs.noaa.gov/cgi-bin/craigs_lib.prl?HELP_NONPUB=1
What stations are NOT published ???
The Latitude and Longitude is not published if one of
the conditions listed below exists:
Surface Mark Reported Destroyed
Surface and underground mark reported destroyed
A-Order Horizontal mark not tied to an adjusted HARN
C-Nonoperational CORS Station
Weakly determined position.
Purpose of position is not for network control
No Descriptive Text available
Restricted position
Outside NGS Publication Area
The Orthometric Height is not published if one of
Bench Mark not yet adjusted.
Presumed destroyed
Restricted elevation
So if a mark is erroneously reported destroyed, how does one get the datasheet if you find it.
Posted : January 20, 2015 11:10 am
Some of the ways of searching their data base (PID, coordinates, etc.) have a check box for "Include Destroyed Marks" or "Destroyed Marks Only"
I have a philosophical difference with NGS over their method of logging destroyed reports. You submit evidence and circumstances, and all they put on the data sheet is "Reported destroyed by John Doe." I wish they would include a statement of those circumstances so later viewers could evaluate the likelihood that the report was mistaken.
Posted : January 20, 2015 11:23 am
(@base9geodesy)
If you know the PID go to "Datasheets by PID" page. In the menu below the box where you enter the PID select the tab that says "Include Destroyed Marks." If you have a mark that was erroneously listed as destroyed send a note to Ms. Deb Brown -- deb.brown@noaa.gov explaining the situation. She can have the datasheet restored.
Posted : January 20, 2015 11:25 am
 vern
(@vern)
Almost always I do a radial search about my GPS base. I just realized that the reported missing were not being returned. No way to really know unless you stubbed your toe on the thing that is supposedly not there.
Posted : January 20, 2015 11:37 am
 vern
(@vern)
I do not see that check box, but I do see a "destroyed marks only" search option. That would seem useless if destroyed is true.
Posted : January 20, 2015 11:42 am
(@timothyhohara)
I wondered how that worked. I reported a station destroyed back in 2011. Last time I checked to see if it had been noted as destroyed the datasheet would not come up, so when I pull by PID and check it it finally showed my report as destroyed. How long does it typically take for these to go through? I would have to say my report took at least 3 years to get processed...
Sad part is that someone stole the brass disk off of this monument. It was located at a high traffic area at the Morehead Planetarium in Chapel Hill, NC. It was located at the base of the Sundial, so plenty of kids could see it and wonder what it was...... http://www.moreheadplanetarium.org/about-morehead
RIP SUNDIAL
http://www.ngs.noaa.gov/cgi-bin/get_image.prl?PROCESSING=get_figure&IID=71393
http://www.ngs.noaa.gov/cgi-bin/get_image.prl?PROCESSING=get_figure&IID=71394
*** NOTE - The station below is destroyed.
1 National Geodetic Survey, Retrieval Date = JANUARY 20, 2015
EZ1375 ***********************************************************************
EZ1375 DESIGNATION - SUNDIAL
EZ1375 PID - EZ1375
EZ1375 STATE/COUNTY- NC/ORANGE
EZ1375 COUNTRY - US
EZ1375 USGS QUAD - CHAPEL HILL (1993)
EZ1375
EZ1375 *CURRENT SURVEY CONTROL
EZ1375 ______________________________________________________________________
EZ1375* NAD 83(2011) POSITION- 35 54 51.97716(N) 079 03 03.45328(W) ADJUSTED
EZ1375* NAD 83(2011) ELLIP HT- 112.081 (meters) (06/27/12) ADJUSTED
EZ1375* NAD 83(2011) EPOCH - 2010.00
EZ1375* NAVD 88 ORTHO HEIGHT - 143.106 (meters) 469.51 (feet) ADJUSTED
EZ1375 NAD 83(2011) X - 982,284.444 (meters) COMP
EZ1375 NAD 83(2011) Y - -5,077,521.749 (meters) COMP
EZ1375 NAD 83(2011) Z - 3,720,572.614 (meters) COMP
EZ1375 LAPLACE CORR - -5.82 (seconds) DEFLEC12A
EZ1375 GEOID HEIGHT - -31.03 (meters) GEOID12A
EZ1375 DYNAMIC HEIGHT - 142.989 (meters) 469.12 (feet) COMP
EZ1375 MODELED GRAVITY - 979,810.6 (mgal) NAVD 88
EZ1375
EZ1375 VERT ORDER - SECOND CLASS 0
EZ1375
EZ1375 FGDC Geospatial Positioning Accuracy Standards (95% confidence, cm)
EZ1375 Type Horiz Ellip Dist(km)
EZ1375 -------------------------------------------------------------------
EZ1375 NETWORK 0.99 1.96
EZ1375 MEDIAN LOCAL ACCURACY AND DIST (006 points) 0.81 1.37 2.36
EZ1375 NOTE: Click here for information on individual local accuracy
EZ1375 values and other accuracy information.
EZ1375
EZ1375
EZ1375.The horizontal coordinates were established by GPS observations
EZ1375.and adjusted by the National Geodetic Survey in June 2012.
EZ1375
EZ1375.NAD 83(2011) refers to NAD 83 coordinates where the reference
EZ1375.frame has been affixed to the stable North American tectonic plate. See
EZ1375.NA2011 for more information.
EZ1375
EZ1375.The horizontal coordinates are valid at the epoch date displayed above
EZ1375.which is a decimal equivalence of Year/Month/Day.
EZ1375
EZ1375.The orthometric height was determined by differential leveling and
EZ1375.adjusted by the NATIONAL GEODETIC SURVEY
EZ1375.in June 1991.
EZ1375
EZ1375.Photographs are available for this station.
EZ1375
EZ1375.The X, Y, and Z were computed from the position and the ellipsoidal ht.
EZ1375
EZ1375.The Laplace correction was computed from DEFLEC12A derived deflections.
EZ1375
EZ1375.The ellipsoidal height was determined by GPS observations
EZ1375.and is referenced to NAD 83.
EZ1375
EZ1375.The dynamic height is computed by dividing the NAVD 88
EZ1375.geopotential number by the normal gravity value computed on the
EZ1375.Geodetic Reference System of 1980 (GRS 80) ellipsoid at 45
EZ1375.degrees latitude (g = 980.6199 gals.).
EZ1375
EZ1375.The modeled gravity was interpolated from observed gravity values.
EZ1375
EZ1375. The following values were computed from the NAD 83(2011) position.
EZ1375
EZ1375; North East Units Scale Factor Converg.
EZ1375;SPC NC - 240,108.589 605,001.868 MT 0.99993936 -0 01 45.9
EZ1375;SPC NC - 787,756.26 1,984,910.30 sFT 0.99993936 -0 01 45.9
EZ1375;UTM 17 - 3,976,213.403 675,862.636 MT 0.99998110 +1 08 36.8
EZ1375
EZ1375! - Elev Factor x Scale Factor = Combined Factor
EZ1375!SPC NC - 0.99998241 x 0.99993936 = 0.99992177
EZ1375!UTM 17 - 0.99998241 x 0.99998110 = 0.99996351
EZ1375
EZ1375
EZ1375_U.S. NATIONAL GRID SPATIAL ADDRESS: 17SPV7586276213(NAD 83)
EZ1375
EZ1375_MARKER: DS = TRIANGULATION STATION DISK
EZ1375_SETTING: 30 = SET IN A LIGHT STRUCTURE
EZ1375_SP_SET: SET IN THE BASE OF THE GNOMON
EZ1375_STAMPING: SUNDIAL 1956
EZ1375_MARK LOGO: CGS
EZ1375_MAGNETIC: O = OTHER; SEE DESCRIPTION
EZ1375_STABILITY: D = MARK OF QUESTIONABLE OR UNKNOWN STABILITY
EZ1375_SATELLITE: THE SITE LOCATION WAS REPORTED AS SUITABLE FOR
EZ1375+SATELLITE: SATELLITE OBSERVATIONS - January 01, 2010
EZ1375
EZ1375 HISTORY - Date Condition Report By
EZ1375 HISTORY - 1956 MONUMENTED CGS
EZ1375 HISTORY - 1972 GOOD NCGS
EZ1375 HISTORY - 1973 GOOD NCGS
EZ1375 HISTORY - 1983 GOOD USPSQD
EZ1375 HISTORY - 1988 GOOD USPSQD
EZ1375 HISTORY - 19910526 GOOD USPSQD
EZ1375 HISTORY - 20000509 GOOD NCGS
EZ1375 HISTORY - 20020316 GOOD INDIV
EZ1375 HISTORY - 20040421 GOOD USPSQD
EZ1375 HISTORY - 20051112 GOOD USPSQD
EZ1375 HISTORY - 20100101 GOOD JCLS
EZ1375 HISTORY - 20110131 DESTROYED NGS
EZ1375
EZ1375 STATION DESCRIPTION
EZ1375
EZ1375'DESCRIBED BY COAST AND GEODETIC SURVEY 1956 (MLC)
EZ1375'THE STATION IS LOCATED ON THE GROUNDS OF THE UNIVERSITY OF
EZ1375'NORTH CAROLINA, JUST N OF MOORHEAD PLANETARIUM ON FRANKLIN
EZ1375'STREET, CHAPEL HILL, NORTH CAROLINA.
EZ1375'
EZ1375'THE STATION IS MARKED BY A LARGE 12-INCH BRONZE DISK, SET IN
EZ1375'THE BASE OF THE GNOMON. IT IS STAMPED SUNDIAL 1956, THE YEAR
EZ1375'BEING SHOWN IN ROMAN NUMERALS.
EZ1375'
EZ1375'THIS STATION WAS LOCATED BY TRAVERSE FROM STATION UNIVERSITY 1933.
EZ1375
EZ1375 STATION RECOVERY (1972)
EZ1375
EZ1375'RECOVERY NOTE BY NORTH CAROLINA GEODETIC SURVEY 1972 (LA)
EZ1375'SUNDIAL 1956 GOOD
EZ1375
EZ1375 STATION RECOVERY (1973)
EZ1375
EZ1375'RECOVERY NOTE BY NORTH CAROLINA GEODETIC SURVEY 1973
EZ1375'IN CHAPEL HILL.
EZ1375'SUNDIAL IS LOCATED ON THE CAMPUS OF THE UNIVERSITY OF NORTH
EZ1375'CAROLINA, JUST NORTH OF THE MOREHEAD PLANETARIUM AND APPROXIMATELY
EZ1375'250 FEET SSE OF EAST FRANKLIN STREET. STATION IS MARKED BY A LARGE
EZ1375'12 INCH BRONZE DISK SET IN THE BADE OF THE GNOMON, AND IS STAMPED
EZ1375'SUNDIAL 1956 (THE YEAR BEING SHOWN IN ROMAN NUMERALS).
EZ1375
EZ1375 STATION RECOVERY (1983)
EZ1375
EZ1375'RECOVERY NOTE BY US POWER SQUADRON 1983 (WKB)
EZ1375'SUNDIAL 1956 RECOVERED GOOD. RECOVERED AS DESCRIBED.
EZ1375
EZ1375 STATION RECOVERY (1988)
EZ1375
EZ1375'RECOVERY NOTE BY US POWER SQUADRON 1988 (RTG)
EZ1375'RECOVERED IN GOOD CONDITION.
EZ1375
EZ1375 STATION RECOVERY (1991)
EZ1375
EZ1375'RECOVERY NOTE BY US POWER SQUADRON 1991 (CSB)
EZ1375
EZ1375 STATION RECOVERY (2000)
EZ1375
EZ1375'RECOVERY NOTE BY NORTH CAROLINA GEODETIC SURVEY 2000 (WLL)
EZ1375'RECOVERED AS DESCRIBED.
EZ1375
EZ1375 STATION RECOVERY (2002)
EZ1375
EZ1375'RECOVERY NOTE BY INDIVIDUAL CONTRIBUTORS 2002 (JDS)
EZ1375'FOUND MARKER WITH RECREATIONAL GPS AT N35 54.866 W79 03.058 IN
EZ1375'CHAPEL HILL, NORTH CAROLINA.
EZ1375
EZ1375 STATION RECOVERY (2004)
EZ1375
EZ1375'RECOVERY NOTE BY US POWER SQUADRON 2004
EZ1375
EZ1375 STATION RECOVERY (2005)
EZ1375
EZ1375'RECOVERY NOTE BY US POWER SQUADRON 2005
EZ1375
EZ1375 STATION RECOVERY (2010)
EZ1375
EZ1375'RECOVERY NOTE BY JOHN CHANCE LAND SURVEYS INC 2010
EZ1375
EZ1375 STATION RECOVERY (2011)
EZ1375
EZ1375'RECOVERY NOTE BY NATIONAL GEODETIC SURVEY 2011
EZ1375'THIS REPORT WAS SUBMITTED BY TIM O'HARA.
Posted : January 20, 2015 1:50 pm
