looking for underground service asbuilt advice
8 Users
Smaxwell
(@smaxwell)
for years we have been measuring inverts of catchbasins, manholes etc for underground services here in canada. always just measured using a tape measure or level rod etc. but more often than not there is an offset pipe invert from the manhole rim that makes it rather hard to measure acurately has anyone seen a special prism pole or built your own device for measuring these offset inverts? ideally i would like to tie them in directly with the gps via prism pole to eliminate error from field crew to drafting etc.
here is an example of what i mean
Thanks
Posted : July 20, 2014 3:22 pm
stephen-ward
(@stephen-ward)
Here's link to one that works on a fiberglass level rod.
Posted : July 20, 2014 3:44 pm
seb
 seb
(@seb)
We have a Leica Disto that does slope and vertical distances so you can point it on an angle from the lip of a manhole to the invert of a pipe and it will give you a vertical distance.
Posted : July 20, 2014 5:04 pm
jimmy-cleveland
(@jimmy-cleveland)
I have a pipe mic that Stephen provided a link to. It has made my invert information much more accurate, and easier to obtain.
Posted : July 20, 2014 5:10 pm
Equivocator
(@equivocator)
We actually hop down into Storm Water Manholes (staff are Confined Space trained) to get a very accurate Invert levels for that.
For waste water (sewer) we use something similar to ones already posted, but built in house.
Posted : July 20, 2014 5:23 pm
ken-salzmann
(@ken-salzmann)
Go to the hardware store and for about $10 you get a plumbers weighted protractor that will give you the slope of the slanted rod down in the invert. A minute or so with your calculator and you have a vertical distance. It is easy to carry around and it works!
Ken
Posted : July 20, 2014 5:36 pm
jimmy-cleveland
(@jimmy-cleveland)
One advantage of the PipeMic is the way you can accurately get pipe sizes.
Posted : July 20, 2014 8:05 pm
JD Juelson
(@jd-juelson)
True, but you can only read the rod from one side! I have one, it sits collecting dust as it is a PITA to use sometimes. Usually just measure the c/l invert
-JD-
Posted : July 21, 2014 8:10 am
jimmy-cleveland
(@jimmy-cleveland)
They actually make a double sided level rod for that!
Double sided level rod
Posted : July 21, 2014 8:36 am
dmyhill
(@dmyhill)
For the most accurate measurements, we enter the manhole. This is kept to a minimum due to safety concerns. We do this with all new construction that we are doing an as-built on.
For location of existing structures, we take into account the situation and the needed accuracy. Most manholes in our area are 48" diameter. This means that measuring with a fiberglass level rod from the invert to the rim at the center of the structure results in a right triangle with the measured distance being the "c", and "b" being 2.0'. Then the vertical distance is calculated. In practice, when we have checked this, if done carefully, this results in repeatable measurements accurate to within +/-0.05' compared with entering the manhole. Our experience is that entering the manhole results in repeatable measurements of +/-0.01', with good care and procedures.
In many cases, the center-line of the channel of the manhole is used, depending on the expected use. Including metadata with measurements allows for the project surveyor or engineer to appropriately use the data.
Posted : July 21, 2014 10:36 am
