leica TCRA 1105
2 Users
(@hristo)
Does anyone know if I can run my robot leica 1105 with my trimble/recon running SurvCE 2.62?
Right now I m using it as a manual TS typing by hand in my data collector.
Thanks
Posted : December 22, 2015 5:04 pm
(@cwlawley)
***In SurvCE 2.58 or higher***
1) Equip / Total Station
2) Set the Manufacturer to "Leica TPS Series (Direct)"
3) Set the Model to "TPS 1100"
4) Tap the Comms tab and set it up for:
Type: Cable
Port: Com1
Baud: 19200 / Data Bits: 8 / Parity: None
5) Tap the "Settings" tab and select your FS Target and BS Target prism options
6) Tap the Green Check in the upper right to save your Changes
Posted : December 22, 2015 7:09 pm
(@hristo)
Thanks a LOT
This is what I got on my data collector
PORT NOT OPEN
unable to set prism constant
unable to set edm mode
port not open
8 not supported
connection not available
cannot open file buil-in storagesurvstarcustomtargetinfo.txt
unable to establish link with device
Posted : December 28, 2015 4:01 pm
