Leica LS15 side shots
2 Users
MJR1349
(@mjr1349)
I am looking for some help with a Leica LS15 digital level. I need to level through about 500 points and the method I usually use is “line leveling”. I’ve always turned through all my FS shots but now I need to be able to set up and shoot probably around 100 points from the same setup. I also need to be able to move forward on my line and turn on some control points. The other issue is storing everything and being able to look at all measurements in starnet. I’ve looked online and the only thing I found even from Leica was using the “Q level “ routine. Will this work or can I do side shots in “line leveling”?  I’ve mostly used Trimble in the past so I’m still a little unfamiliar with Leica. Any help would be greatly appreciated.
Thanks
Posted : January 14, 2026 9:59 pm
sireath
(@sireath)
You can do side shots in line levelling, you can do after your BS shot but before your FS shot.
After the BS Shot, you need to find the key for intermediate shot to shoot and store them before going to your FS shot
Posted : January 15, 2026 9:01 pm
