Leica 1200 port pinout
2 Users
Any you folks have the pinout for the data/power port on the 1200 series? I have a TCRP1205+ but I imagine all models are the same. The port configuration does not show up in the manual.(not sure why)
Thanks, Rob
Posted : March 4, 2019 6:30 pm
Gene Kooper
(@gene-kooper)
The pin assignments and sockets are located in Appendix D of the Leica GPS1200 Technical Reference Manual.?ÿ I found this download for it.?ÿ If you cannot download from this link, I'll upload the 14 MB PDF file to my Box.com directory and provide you with an anonymous link.?ÿ Check out pages 1328 through 1334 for the info on the receiver.
ETA:?ÿ Oops TPS not GPS dummy!?ÿ The pin assignments and sockets are located in Appendix D of the Leica TPS1200 Technical Reference Manual and here is the download for it.?ÿ If you cannot download from this link, I'll upload the 12 MB PDF file to my Box.com directory and provide you with an anonymous link.?ÿ Check out pages 1320 through 1322 for the info on the instrument.
Posted : March 4, 2019 7:29 pm
Thanks Gene but I need the pins on the 1200 series Robotic TS with the 5 pin Lemo-0 connection that combines data and power thru the same fitting
Posted : March 4, 2019 7:39 pm
Gene Kooper
(@gene-kooper)
See edit above.
Posted : March 4, 2019 7:44 pm
Thanks again Gene! That manual is much more comprehensive than the operational one...
Posted : March 4, 2019 10:04 pm
