Hello All
On our rail topo jobs we run into rock faces now and then and are going to demo 3
units to measure to rock face break/fault lines for DTM model then blue tooth the vert angles and compass and dist from range finder to rtk / carlson offset routines for range finders
units on demo
Laser ace 1000
360 b true pulse
Impulse 2000
Have any out there used these units with RTK to fill in the dangerous bits of rock
what do you think.? of above or others
Don' want to use a reflectorless TS / scaning for ten shots and getting to old for the ropes.
Job does not require TS/scanner accuracy.
use paint balls to mark shot points as best can so sights are short 10-30 meters max
Thanks
PK
Carlson SurvCE Ver 2.55
Carlson SurvCE Ver 2.55.10
2 New Carlson Surveyor Plus
Geo 650 robot # 79 Firmware 696-03.08
Geo Radios @ 458.525 Mhz Ch 1
Sokkia Gsr1700Csx RTK L1 Two rovers, One base
post process soft Spectrum Ver 4.21 L1 dongle
Satel 3ASd 1 watt, Stubby, 15cm, 30 cm GainFlex
Computer Hp Pavilion Core2 Quad 6 GB Ram
Vista 64
Nvidia Geforce 9500 GS 512mb Video Card
Autodesk C3D 2011 subscription
AVG Antivirus
HP 111 Roll feed 24" plotter
Sounds good to me. We're probably going to pick one of these up for surveying trees and things that the GPS can't get to.
Just waiting to find a way to tie it into our old, Bluetoothless 1200GG.
