Does anyone know if a 300' roll will work on one of these? I am ordering some paper for a relative.
Mine will only handle a 30" wide roll, never seen one 300 ft wide,;-) . I use single sheets 18" X 24" almost exclusively.
jud
I believe from the one here at the office they will only take up to a 150' roll in either 24, 30 or 36" width.
Thanks. 🙂
I can't see why it wouldn't. It is just a bigger roll. I looked at mine and it might be a little tight but should work.
I'm pretty sure that there isn't enough space between the spindle and the body of the machine for a 300' roll to fit. Also some of those older plotters have a cover that is supposed to flip up and over the roll when it's mounted.
I use 150 footers.
Can the supplier give you a diameter on the 300 foot roll.
What's the cost per foot?
Rick
I don't believe a 450 will hold a 300' roll.
How about two 150' rolls...
