How to evaluate uncertainty in an azimuth
12 Users
(@cf-67)
Honorable Member Registered
Say I want to establish a baseline by running static at each end - and I know the horizontal uncertainty of the coordinates (@95%) is going to be +/-10mm for each point - And I wish the azimuth uncertainty of the baseline to be +/-20"....how long would the baseline need to be?
Pointing me toward some pdf on the subject would be appreciated, or a formula. I know I did this in college but it's gone through the sieve of my brain.
Is it the propagation of errors equation?
Posted : 23/07/2020 4:42 pm
Illustrious Member Registered
if you use 2 static receivers, simultaneously, in clear areas, (no obstructions),?ÿ your accuracy for establishing directional control, will be much better, than if you perform 2 OPUS observations, with only 1 receiver.
Relative positioning can be real good, with 2 units.
I used to run a cluster of 6 L1 post processed gps units.
I got a good "feel" for it. Alas! I've fallen into the big dark hole of rtk!?ÿ
🙂 Kent MC could run the numbers on the back of his hand!
Posted : 23/07/2020 4:58 pm
(@cf-67)
@nate-the-surveyor
Yes I would rather process the baseline than do 2 opus's, but since moving to Windows 10 I've had no luck getting GNSS Solutions to work - I think it's dead...Someone wants me to calibrate the heading sensors on an 8m boat - trying to think how to do it. I even had a look for Polaris last night. It's a real neck breaker at lat 48 degrees!
Posted : 23/07/2020 5:07 pm
Maybe you could:
Put 2 stakes in the ground, intervisable. GPS on these. 1/4 MI apart.
Then, use total station to transfer it to the boat.
Or to the dock. Some mechanism where he can re calibrate anytime, as desired.
Way back when I took a few flying lessons, we'd calibrate the gyro to the compass, and confirm it with the runway direction.
He may not be able to benefit from greater than 1/2 degree accuracy.
Dunno.
Posted : 23/07/2020 5:38 pm
(@cf-67)
It's a commercial boat on Lake Superior - I have asked what the accuracy spec is they require but then I'm asking myself "how do I evaluate the accuracy of my azimuth anyway?" How do I turn the coordinate errors I will know into an azimuth error??ÿ
Posted : 23/07/2020 5:52 pm
Just draw a thin triangle.
Sideways error = Distance * tangent(azimuth error)?ÿ?ÿ
where both errors are at the same confidence level standard error=1 sigma, 90%, 95%, or whatever).
If you do independent observations good to 10 mm the sideways error estimate will be 14 mm (square root sum of squares of individual errors).?ÿ?ÿ For 20" then we get 0.014 meter / tan(20") = 145 meters.
As noted above, the relative position error for simultaneous observations over moderate distances will be much better than the absolute errors.
Posted : 23/07/2020 6:11 pm
(@john-nolton)
@cf-67 Question:  How accurate is the heading sensor on this 8 metre boat?
JOHN NOLTON
Posted : 23/07/2020 7:17 pm
(@cf-67)
@john-nolton
Good question
 I believe 0.015 degrees or about 1'
Posted : 23/07/2020 7:56 pm
(@cf-67)
@bill93
Ok, that's not as complicated as I thought. :d
Posted : 23/07/2020 7:58 pm
Posted by: @cf-67
Ouch. I find it hard enough at 42 latitude.
Posted : 23/07/2020 8:05 pm
(@richard-imrie)
Noble Member Registered
Just quietly, our bathymetric survey kit has an external GPS+GLONASS antenna with a heading sensor in it. Here it is on the far right of the photo (taken with my 0.8MP phone camera), and it's the cat's meow. The antenna is NMEA 2000 linked to the sounder/chartplotter which is used to navigate when doing the sounding runs. The antenna heading sensor is calibrated via the settings in the chartplotter, and involves doing circles until it says she's ok.
DSC 0000080
(@cf-67)
Looks like a nice office!
This calibration is quite involved - I would be shooting the fore and aft sensors with the boat on land to give them a starting azimuth to dial in - then the boat goes in the water, tied to the dock - I shoot them again - compare with the heading sensor - then the boat is turned around and repeat...I'm not scared of anchor bolts, but this job has me a bit worried 😛 ?ÿ
Posted : 23/07/2020 8:15 pm
(@richard-imrie)
@cf-67
It was, and it came with lunch (on all of the 7 days):
DSC 0000070
The hype for that particular antenna (Lowrance Point-1) says:
  • Integrated electronic compass provides 10Hz heading for chart stabilization and radar overlay, plus accurate course over ground even at low speeds.
So I suspect that is what the running circles calibration is about.
Posted : 23/07/2020 8:27 pm
(@john-nolton)
@cf-67 Thanks for the link above on the sensor. Besides doing something like Nate the Surveyor said in his post above about
laying out control I would think that NGS has a lot of control around Lake Superior. Give us Lat/Long of about where the boat will be on land and we can search and see what they have. Come off their control and check your GPS then do a pre-analysis in some software
(star*net is used by most surveyors on this board) and go from there.
JOHN NOLTON
Posted : 24/07/2020 5:30 am
(@larry-best)
Prominent Member Registered
@cf-67   Bring the boat down to a reasonable latitude.
Posted : 24/07/2020 7:42 am
Page 1 / 4
Share:
