H/W = Husband And Wife, As I understand It
How is that different than "John Doe & Dick Smith, as joint tenants" ?
The divorce option is not there, but it's probably easier to get the joint tenancy dissolved into tenants in common, rather than going through a divorce proceeding.
Different Enough That It Is Not Used Around Here
Joint tenancy can also include 3 or more.
In PA I believe one tenant can encumber the property.
I do not know it all which is why I brought up the initial question.
Marketing Question for Paul PA
Paul, it sounds as if you are gearing up your practice to specialize in surveying for same-sex couples and are wanting to get all the details correct. I certainly wouldn't criticize you for doing that, but how to you go about marketing to a mostly gay and lesbian clientele if you don't mind letting us all in on the secret? Do you find yourself dressing differently when you meet your clients?
Politics Has Nothing To Do With Language Of Property Rights
Like I said, I believe Peter (and several others) answered your question up above.
Interesting Question Kent
But since I have never done personal marketing in my career why would I start now?
However, if you were interested in getting into that market, I would recommend the "word of mouth" strategy.
Okay, so you're planning on spending lots of time doing the "meet and greet" with gay and lesbian groups to let them know that when they need a surveyor, you'll be the fellow who is sympathetic to them and who will be able to draft the deed correctly so that their "marital rights" are preserved as well as any same-sex couple's are?
Paul may be looking for a new niche.
I think it's great that Paul is planning ahead to get all the details of the deeds he'll be drafting for his same-sex couples correct. It's not a problem I've ever had to contend with, but it sounds like there is much more demand for it in Pennsylvania. I guess that's Adam Smith's invisible hand of the free market in action.
Do you know what a gay horse eats?
Haaay
So, it seems that married couples are protected somewhat from acts of one that might detrimentally affect the other under the tenants by entirety. Whereas the mere normal joint tenancy does not provide protection against detrimental acts of other joint tenants. This seems a bit strange, as one would think a marriage to be the closest kind of partnership and the law should work the other way around.
The discussion has not been entirely without merit. It seems that a survey contract for a parcel involving tenants by entirety had better have the signatures of both partners in order to insure payment. For a joint tenancy, any one of the tenants signatures would seem to be sufficient.
For Gay couples I would get both signatures just in case (assuming I knew).
It does seem like an issue that's probably already been litigated somewhere.
Interesting distinction. If Paul takes the short cut of just getting one partner of a gay or lesbian couple to sign a contract for his services, would he also forfeit his right to file a lien against the property, assuming that surveyors can do so in Pennsylvania?
