Steve Gilbert, post: 411117, member: 111 wrote: Will it work by itself?
No Sir, the tip is sealed from the elements and has no speakers. The tip links bluetooth to the LS and all audio comes from the LS.
Adam, post: 411119, member: 8900 wrote: No Sir, the tip is sealed from the elements and has no speakers. The tip links bluetooth to the LS and all audio comes from the LS.
What is the LS?
Steve Gilbert, post: 411121, member: 111 wrote: What is the LS?
Javad's receiver for Land Surveyors (LS)........ https://www.javad.com/jgnss/products/receivers/triumph-ls.html
Similar process many times. More typically I will have a sideshot to the monument from my TS and simply repeat the sideshot once the filling/packing/refilling/repacking/monument setting is complete.
The challenge comes with finding an appropriate way to set a worthy monument if the old one is a bit too shallow for the standard two-footer.
If the monument is a rebar, use a pipe that slips over it; if a pipe, set a rebar inside it.
I do it all the time, ESPECIALLY if I suspect a landowner will pull the surface one out.
File a report.
