File Conversion
5 Users
Brent Webster
(@brent-webster)
I have a job file from a Trimble TSCe that I need converted to a text file. I just need the points in either a txt or csv file for insertion into Carlson. My TGO software is on the fritz and all I have is the job file. I don't have the data collector either. Long story. Apparently ForesightDXM doesn't recognize a Trimble job file and it won't convert the dc file either. I am starting to think I may have a corrupt file. Anyone willing to take a shot at it?
Posted : September 7, 2011 12:15 pm
surveyoron
(@surveyoron)
Terramodel can import the raw .dc file and then export a .asc file which can be opened with a text editor such as notepad. If you need someone to convert it send it to me: [email protected]
Posted : September 7, 2011 12:33 pm
Brent Webster
(@brent-webster)
False alarm. TGO still not working on current computer, but managed to find an older version on another computer. Thanks to those who thought about it though.
Posted : September 7, 2011 12:34 pm
Brent Webster
(@brent-webster)
Thanks
Tom Bushelman
(@tom-bushelman)
I coughed up the cash for the Foresight software which I just use for conversions. It would be great to be able to plug the downloaded file directly into Carlson.
Posted : September 7, 2011 12:43 pm
Kris Morgan
(@kris-morgan)
Brent, it's in Carlson already
Check this out dude. In Carlson, Survey>Edit Process Raw Data>File>Import>From Trimble and then you have your very own raw data file with which you can edit, and reduce.
Posted : September 7, 2011 12:50 pm
Kris Morgan
(@kris-morgan)
Tom
See my reply to Brent. Like Prego, It's in there.
Posted : September 7, 2011 12:51 pm
Brent Webster
(@brent-webster)
I didn't have the dc file until just a few minutes ago. The data collector is in the shop with the robot. I had the technicians email me the job file because they apparently don't know how to export a points file.
Thanks for the info though. I hadn't ever done it that way. Learn something new everyday. One question though, how do you get the sideshot records to be recognized as points?
Posted : September 7, 2011 12:58 pm
Brent Webster
(@brent-webster)
I just did what Kris said and it worked pretty seemlessly. Only problem I had though was that when I tried to save the coordinate file it didn't recognize the sideshots. Sure it's just a step I'm missing since I don't normally insert my points this way.
Posted : September 7, 2011 1:01 pm
Kris Morgan
(@kris-morgan)
You may have to fix the records from DS to SS and then they will reduce. I had that problem with traversing with the robot.
It's pretty handy, no?
Posted : September 7, 2011 1:09 pm
Brent Webster
(@brent-webster)
Nevermind Kris. I played around with it a bit and figured it out. This may be the new way I get points into a drawing. Very cool.
Posted : September 7, 2011 1:10 pm
Kris Morgan
(@kris-morgan)
Glad I could help.
Posted : September 7, 2011 1:11 pm
Dennis Devriendt
(@dennis-devriendt)
Do you have Windows7? TGO no longer works on Windows7, it has been replaced by Trimble Business Center (TBC). You can download a 30-day full-licensed trial on http://www.trimble.com/TBC_DemoDVD.html . After 30 days you can still use the software without a license, and use it to import/export your data to your device. The 'custom export' tool is what you will need.
Posted : September 8, 2011 1:41 am
