HEllo Everyone,
does anyone know a way to access a collector over wifi? I wanna eliminate the step of plugging in via USB to my computer. Its a ranger3/tsc3. Maybe using Mobile Device Center to do a sync perhaps.:-S
Any ideas guys?
My ranger3 has WiFi. So I turn on this option"only when I transfer data bc it does eat up the battery ". Now I use survey pro software.So if u use survey pro, there is a share tab within the file tab that I press. Then I either have the option to use the dropbox program or email to upload my Raw file .if you are going to use the email sharing option you need to setup the gmail account in Windows first. If u don't have a drop box acct u can set that up online for free and invite any coworkers to it so they can pull the data when they need it. I hope this helps. I love transfering the data in my driveway before I even enter my house!
Bc i failed to read ur question fully the first time. Here is more info for u to chew--Under the share tab there is an active sync option also.
It's called mapping a network folder . This will get you what you need..
Could you send a link perhaps? I'm not sure how to configure that in windows.
Thanks
