Control point
8 Users
spledeus
(@spledeus)
3 units are better than 2.
All with some static memory I hope.
120km will require some time for an accurate position. I would run OPUS in 2005-2008 with 6 to 8 hour sessions and get decent results with the nearest CORS at 100km. Yours will need some more as it is one base at 120km.
Otherwise, think triangles. Run the base from one point or move it around as you move around the other 2. Try to keep things evenly spaced. Short baselines can process well after 15 minutes, but more time is better.
Sent from my SM-G930V using Tapatalk
Posted : April 21, 2017 6:58 pm
