Control Adjustment Tolerance
2 Users
(@mccracker)
A three wire level run closed out within 0.008, given random and rounding errors in approximately 3500 ft. This is well within the given minimum technical standard but it got me thinking.?ÿ
With techniques out there for proportioning the error, is it worth it? For time and accuracy sake I think not unless the control was to be at a given precision for the project. For general third order conventional levelling I don't think adjusting turning points for .008 is worth it. Do you?
Posted : 29/07/2019 5:31 pm
Posted by: @mccracker
I do. Because it is so easy to do. If you are asking if if I think it is necessary, probably not.
Posted : 29/07/2019 5:36 pm
(@mccracker)
Posted by: @norman-oklahoma
Right on. Unless the project was specifically required to be tighter on paper I feel that unless using well calibrated robotics or digital levels, closures in this distance would be typically around .01. It is well above the minimum technical standard and that is really what matters. I suppose .008 would be project dependent.?ÿ
Posted : 30/07/2019 3:27 pm
