condominium projects
5 Users
 JLE
(@jle)
we have been asked to change the unit dimensions for 2 units of an existing condominium project. the change is an addition to one of the units plus a new area (a second floor over the existing unit) and making the other unit a bit smaller.
this is a project in Michigan.
the condominium project is 7 1/2 years old from the recording date of the master deed.
are we allowed by law to amend the condo after 6 years?
Posted : December 17, 2013 6:54 pm
Can't speak for Michigan; but around these parts any rules or specifications for amending and restating the condominium will be set forth in the condominium declaration.
Posted : December 18, 2013 5:35 am
Ask the Owner's attorney...
Posted : December 18, 2013 8:07 am
(@dallas-morlan)
Making changes of this type may involve state laws, local planning and zoning, and the condo association approval. The approval process may have many steps prior to the need for a survey. Research the approval process for new condos first, contact the agencies involved and ask questions about subsequent modifications or amendments. Keep those questions generic enough that the specific condo involved is not identified.
There is likely an attorney already involved. Unless that attorney has worked with similar projects be prepared to provide them with the information you have researched.
Posted : December 18, 2013 9:25 am
(@toivo1037)
Yes you can. Association will need an Atty. You will be filing an amendment to the Master deed, and attaching a new exhibit B drawing. Not too painful, but you/Atty will need a vote of the owners in order to do so, as it is required in any Master Deed change.
Most condos I work in, building or site have 1 or more amendments. You can do them at any time.
Posted : December 18, 2013 1:18 pm
