Civil 3D surface and scaling
(@iwisuri)
When you use the scale command in civil 3d it scales a surface (or any object) in the x, y, and z direction. Is there a way to scale only in the x and y?
Posted : October 27, 2014 10:51 am
If The Surface Is A Block
You can insert it and scale X & Y different from Z. It is possible that doing that disables certain options down the road.
Posted : October 27, 2014 10:56 am
(@wa-id-surveyor)
I've never had the need to scale a surface and can't think of a viable reason to do so. With that said, your probably best served by going back to the source data (coordinate values) and scaling them in excel.
Posted : October 27, 2014 11:15 am
Coordinate Values?
Coordinate Values can be scaled XY in Carlson Survey without scaling Z. I do it all the time with my GPS observations.
Posted : October 27, 2014 12:16 pm
(@clb-surveyor)
Coordinate Values?
Check out Sincpac for Civl 3D by Quux Software. It has a scale XY routine that works great among so many other wonderful little things that make Civil 3D bearable for the surveyor.
I am not affliated with Quux.
Also something else to consider. You should scale a Civil 3D surface. You should scale the entities that make up the surface, hence the surface will rebuild to represent the data that has been scaled.
Posted : October 27, 2014 1:57 pm
(@wa-id-surveyor)
Coordinate Values?
Yes, Sincpac is worth it's weight in Gold! Can't live without it and the price is more than right.
Posted : October 28, 2014 6:13 am
