Colleagues-
As we do not "do" ALTAs in Ontario, 'tiz up to y'all sublatitudinals to enter the fray
Cheers
Derek
_________________________________________________________________________
I had a couple of questions regarding the new ALTA/ACSM survey standards on which I was hoping to get input from title gurus. These are asked from perspective of commercial mortgagee:
1. The new ALTA/ACSM survey standards don’t include the language from the old certification to the effect that the property is the same as that described in the title commitment, but instead just call for a note identifying the commitment. Does this omission create any new requirement for issuance of the “same as survey” endorsement?
2. How are title companies handling the requirement for identification of E&O coverage limits for the surveyor? Do they look for any correlation to loan amount? Does omission of the item from Table A have any coverage implications?
Thanks for your attention to this.
Regards,
Chris
Christopher J. Devlin
Senior Counsel, Investments
Unum
2211 Congress Street, C474
Portland, ME 04122
207-575-4218
207-575-1296 (fax)
cdevlin@unum.com
* This e-mail was sent from Unum’s Legal Department, is covered by the Electronic Communications Privacy Act, 18 U.S.C. Section 2510, et seq., and is legally privileged. The information contained in this e-mail is confidential and is intended only for the use of the individual or entity named above. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited; you are also requested to please reply to this message by notifying the sender that it was sent to you in error and delete it from your system.
To add or remove from this mailing list, please go to or send an email message to the address listserv@listserv.umkc.edu, with the text SIGNOFF DIRT in the body of the message.
You are subscribed to the DIRT list as &*TO;.
Problems or questions should be directed to manager@listserv.umkc.edu.
You are subscribed to the DIRT list as derek@GRAHAMSURVEYS.ON.CA.
Bumping TTT for Derek. 🙂
