ADJUSTMENT OF RAW DATA USING CARLSON SURVNET
(@dennis_kim)
Hi Everyone, I am quite new to using Carlson Survey but have a lot of experience in Autocad Civil 3D. I am trying to adjust the survey points shot with Total Station using Controls Shot by GPS. I am getting errors such as "zero degrees of freedom,no horizontal adjustment performed" when I try to use the Survnet to perform the adjustment. I would like some guidance on how to perform the adjustment using this software. The data files are attached.
Dennis
Posted : 18/05/2022 1:27 am
Your file looks like coordinates, not measurements.
Posted : 18/05/2022 7:37 am
(@sergeant-schultz)
That's not raw data.?ÿ SurvNet has no idea what to do with that, and told you so.
Raw data file should have .rw5 extension.?ÿ?ÿ
Posted : 20/05/2022 5:42 am
(@ladd-nelson)
Agreed. Adjustment packages like SurvNET prefer to work with measurements as opposed to specified coordinates. Presuming you have the "raw" measurements available, you might explore the SurvNET tutorial and/or the SurvNET documentation for inspiration.
Alternatively, there is some SurvNET material available on the Carlson YouTube channel.
I hope this information helps.
Posted : 20/05/2022 5:52 am
