XML files- some data not showing up
2 Users
(@lanceboyle93101)
Reputable Member Registered
Carlson Survey user.
Recently discovered polyline files as another option to include 3D lines in XML files. Created xml file with *.pln and *.crd files.
However when import xml into a blank dwg (as a test before I send to client) lines or points do not show up. Tried a couple different formats.
Polyline file format [<Carlson>/DTM/Idan/Kof/microStation/MOSS/Peabody/Topcon]?
Ideas?
We use XML files to transfer up and down to ranger DC's every day. Not new to that.
Posted : 20/07/2023 4:23 pm
(@va-ls-2867)
Honorable Member Registered
You need to export a polyline file (PLN) of your breaklines and inclue that in your xml export
Posted : 20/07/2023 5:03 pm
(@lanceboyle93101)
Yes, that is what we do. Import *.pln and *.crd files into *.xml
Here is a snip of the XML.
xml codes indicate a points list and lines list
Clipboard01
IMport to blank dwg and lines do not get drawn. Points drawn. All layers on/thawed
Posted : 22/07/2023 1:57 pm
(@va-ls-2867)
Are you checking both options when importing the xml?  It will write out a PLN file when checked, not just the surface file.  The linework will not import as part of the surface tin.
Posted : 22/07/2023 5:18 pm
Share:
