Has anyone seen this?
Running Carlson 2013 w/Intellicad
Windows 7 pro
HP L7780 printer w/dual feed trays, latest drivers recently installed
When I go to print an 8.5x14 plat I try to set up the printer to feed from the proper tray. In the print menu, everything looks ok but it prints from the wrong tray. If I use the print menu (properties button)to change the output tray, the print dimensions in the menu change from 8.5x14 to 215.9x279.4 inches. Why would changing an output tray do this? None of my other software seems to be having an issue.
Some how it got changed to metric.
Mine does it too.
Devices and printers
Adjust printer options
custom
change from metric to english
hope this helps.
mine seems to switch over at random.
This happened to me in Windows 7 and now 8 using Carlson with Icad.
Hope this helps.
