Question for the smart people, I have a Trimble TSC2 with survey controller 12.50. It connects to WMDC, and then to Data Transfer via Survey Controller on Active Sync....no problems there...but...I have another TSC2 with Acess 2016.02 that connects (finally) to WMDC but Data Transfer and TGO 1.63 doesn't recognize the collector.....is there a special name to connect to the Transfer Utility using Access? Thanks....
http://www.trimble.com/installationmanager/
In case you don't have it... use the Online version if you're generally connected to the internet. You won't have those drivers if you've never used TIM to update your PC.
That worked...already had updated TIM, used the General Survey and everything works just fine....Thank you Lee D...you are well versed with Trimble products...thanks again...Ron
rberry5886, post: 399928, member: 232 wrote: That worked...already had updated TIM, used the General Survey and everything works just fine....Thank you Lee D...you are well versed with Trimble products...thanks again...Ron
Glad I could help.
