Does anyone have any experience with Terramodel Links. I just discovered the link settings but i can't view them. I also would like to see link slope.
Jason,
Apologies for answering a question with another question.
For a given DTM layer the Link Settings can show you the triangle edges, the contours and the triangle slope directions.
If you need the the actual slope values for each triangle you need a completely separate option.
You can also set up the Coordinate Scroll Box so that it shows the slope values as you move the mouse around.
Is this what you mean?
Regards,
jerry
jason johnson, post: 419288, member: 10590 wrote: Does anyone have any experience with Terramodel Links. I just discovered the link settings but i can't view them. I also would like to see link slope.
In the links settings box there is a box that says "Display Links". Check it and select the layers you want to see. May have to hit redraw for them to show up.
Great thanks,
also, When I saw the "Show triangle slope" I assumed it would show the actual slope for each triangle not just a little arrow. It would be helpful for determining steep slopes.
