TBC without lidense and editing attributes
2 Users
(@arctanx-2-2)
Honorable Member Registered
I have a job that I've collected points with attribute information on. Is there a way I can edit those attributes in the free version of TBC?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Posted : 27/08/2015 6:23 am
 vern
(@vern)
Noble Member Registered
I think you could do them one at a time. A batch edit would be problematic even with a license.
Posted : 27/08/2015 6:43 am
(@arctanx-2-2)
The attributes do not come filled in (in the properties tab) when I import the job file. The attributes are there but the values are not. I do need to edit them one at a time.
Any ideas as to which tool or process needs to take place here?
Posted : 27/08/2015 6:48 am
 vern
(@vern)
Select a point, right click, choose properties. You should be able to edit the attributes on the right side window that comes up.
EDIT: The better way to do it might be to download the ASCII File Generator from Support A-Z. Then you can edit in notepad or Excel.
Posted : 27/08/2015 6:51 am
(@arctanx-2-2)
The attributes are visible it's just that the values are not displayed when I right click and go to properties. I can manually input the values but that defeats the purpose of collecting most of the information in the field. I would rather not have to edit in an ASCII - I like visually seeing where I am on the drawing.
Posted : 27/08/2015 7:28 am
Share:
