TBC/Intellicad
5 Users
(@burnormj)
Trusted Member Registered
Quick question: Is there a way in TBC or Intellicad 2020 to see where each shot has been taken from? I have once seen in TBC each set up with lines going to each point that was shot from that set up but have been unable to figure out how to turn that on and off. Also if there is a way to do the same in Carlson with Intellicad 2020.
Thank You
Mike
Posted : 23/03/2020 7:07 am
(@alan-chyko)
Estimable Member Registered
In TBC, open up the View Filter Manager and then under the "Raw Data" subsection make sure that "Total Station" is enabled.
Posted : 23/03/2020 7:15 am
(@burnormj)
@alan-chyko Do I have to Regen the drawing to see?
Posted : 23/03/2020 7:27 am
(@steinhoff)
@burnormj
 In case you're one of those people who love to see a picture (like me). You shouldn't need to regen afterwards.
Posted : 23/03/2020 7:29 am
(@burnormj)
@steinhoff Thank you that's exactly what I'm looking for, I enabled everything still cant seem to get it to work, I have attached a picture i may have missed something
Clipboard01
Posted : 23/03/2020 7:39 am
(@steinhoff)
@burnormj
Let's try this: please double check that you're showing your sideshot observations (see below).
EDIT: *ALSO*... I'm assuming you've directed imported your .job/.jxl/etc. file- if you've only imported a .csv, you won't be able to see your total station vectors.
Posted : 23/03/2020 7:43 am
(@rover83)
Noble Member Registered
@burnormj
Just to check, what type of file are you importing into TBC? It looks like all you have is a point file, not a raw data file.
Posted : 23/03/2020 7:46 am
(@burnormj)
@rover83 That was it, I had imported it as a CSV, when I pulled it directly from the device pane it all showed up. This is why I like this forum. Now taking a step further we at the office usually use Carlson w/ Intellicad 2020, is there a similar way to do that in that program. Showing where each shot was from?
Posted : 23/03/2020 7:59 am
(@va-ls-2867)
Honorable Member Registered
@burnormj Yes, in the edit/process raw data, select display on the menu bar and turn on graphics. you can turn sideshots off/on there.
Posted : 23/03/2020 8:34 am
Share:
