Single line text to Multi-line text in Carlson 2008
5 Users
(@jimmy-cleveland)
I am using Carlson 2008 embedded Autocad, and was wondering if there is a way to convert single line text into multiline text?
I used to be able to use a lisp routine to accomplish this, but you can't use lisp routines in Carlson.
Any advice is greatly appreciated.
Thanks in advance,
Jimmy
Posted : February 17, 2013 9:38 pm
(@mike-lacey)
I copy the single line text in the text edit routine, and past it into the m-text box.
Posted : February 18, 2013 3:55 am
(@glenn-breysacher)
You can use lisp routines in Carlson. I know, I use them. You just can't use them in stand-alone Carlson from what I understand.
Usually, I do as suggested above, copy and paste into MTEXT. However, I also have a lisp routine for doing that. It's not the best, since some punctuation and otherstuff sometimes gets goofed up, but it beats re-typing the whole thing.
Posted : February 18, 2013 7:02 am
(@peter-hughes-davies)
I understand that Express Tools was integrated with newer versions of AutoCAD so perhaps txt2mtxt at the command line will work.
Peter
Posted : February 18, 2013 9:34 am
Probably Not
Autodesk goes out of their way to disable as much as possible in the lower cost AutoCAD engine they provide to Carlson.
Posted : February 18, 2013 9:55 am
