Does anybody have a "cheatsheet" for connecting to the ORGN using Survey Pro 4.2?
I am going to try connecting a Trimble 5800 via a TDS Ranger running Survey Pro 4.2.
I would suggest contacting Randy Oberg at ORGN if you haven't already tried that.
Another option would be to take the one day class that he and Ken Bays will be teaching at OSU. I don't have the date right now but just take a look at the OSU CE website.
Good suggestions, thanks John.
I have read the network connection section in the TDS manual, but I see ODOT has guidance docs for Leica and Trimble data collectors.
I will do some more research.
Been a while but see if this might help! Jp
ORGN
R8 and TDS Survey Pro v4.7
AT&T MOTOROLA RAZR V3xx
EQUIPMENT:
• PHONE: AT&T MOTOROLA RAZR V3xx
• DATA COLLECTOR: TRIMBLE TSC2, TDS SURVEY PRO 4.7, WINDOWS MOBILE 5.0
• GPS RECEIVER: TRIMBLE R8-GNSS
Step One:
Establish a pairing between the phone and the ranger data collector. To do this each component
needs to be set to “discoverable mode” under blue tooth settings. Once this is complete should not
need to be done again.
Step Two:
Set up a modem connection through settings on the ranger data collector. This is done within the
operating system of Windows Mobile 5.0, not survey pro.
GO TO: Start, Settings, Connections, Connections, My ISP-add new modem connection:
• give a name for connection (ODOT), select Bluetooth under modem type,
• Choose Motorola Phone (NEXT)
• Number to Dial *99# (NEXT)
• User Name: WAP@cingulargprs.com
Password: CINGULAR1
Domain: BLANK
• SELECT Advanced:
o General- Baud Rate 115200, wait for dial tone,
extra dial string: +CGDCONT=1,”IP”,”ISP.CINGULAR”
o Port Settings- (8, N, 1, N) NOTHING CHECKED FOR TERMINAL
o TCP/IP- check use sever assigned IP address, use software compression,
use IP header compression
o Severs- check use sever assigned addresses
OK FINISH
CHOOSE CONNECTION JUST CREATED-OK
Step Three:
Open desired job with in Survey Pro. Next under Survey select “Start GPS Survey”. Select Use Remote
Base. Now a RTK Rover needs to be set:
• Manage Instruments:
o Create New Receiver (only once)
? Name: ORGN-R8
? Brand: Trimble
? Model: Trimble R8-GNSS
? DC Port to Receiver: Bluetooth
? Bluetooth Receiver: R8-3, 4921173291: Trimble
• Choose Receiver Settings:
• Receiver- NTRIP ROVER, 10 degrees
• Data Modem- Windows Network,
choose dial-up connection (ODOT), 167.131.109.57/9881
• SHOW ADVANCED SETTINGS: APN=ISP.CINGULAR
• OK, OK
• Activate Receiver, OK (if receiver is already created start here)
• Connect
• Measured: 2m or 6.562 feet , offset: 0.213 feet
• Post processing recording interval: Off
• SET ROVER
• Select an NTRIP Service: IMAX_RTCM3
o User Name: MED1 (uppercase)
o Password: MED1 (uppercase)
o Save user name and password: Check
o CONNECT
You are now receiving RTK Corrections from the ORGN.
JP
Pretty darn good memory there!
