NGS DATASHEETS on IPAD
(@ekillo)
I recently got an IPAD to get my email and to able to look up datasheets while in the field and also GE. The only problem is that once I enter the center LAT and LONG on the IPAD, it always come up and says 0 stations found. Does anyone have any ideas what maybe wrong? TIA
Posted : 05/05/2014 1:37 pm
(@m-h-taylor-2-2-2-2)
Are you entering a radius?
Henry
Posted : 05/05/2014 1:45 pm
Is the NGS site working for people today? For some reason I can't get data sheets.
Posted : 05/05/2014 1:49 pm
(@david-livingstone)
I have limited success using the radius with a center lat and long also. I don't think I was doing it wrong, just some kind of glitch. I usually do it by county but depending on the county that could give you a lot of results.
Posted : 05/05/2014 1:50 pm
(@ekillo)
Yes, I have tried the default .5 mile all the way out to 20 miles. I know the stations are there because I can find them on the Laptop and office computers. I wanted to be able to view them in the field to save some paper by not having to print a bunch off and then use the first one that I look for.
Posted : 05/05/2014 1:51 pm
(@ekillo)
I have tried that too without any success. I use the site regularly using the radial search with good results.
Posted : 05/05/2014 1:53 pm
(@kevin-samuel)
I had a similar problem on my iPhone 4s, or so I thought.
The results were there, I just had to tap the 0 item option to see the results.
https://surveyorconnect.com/images/uploaded/20140505224235536813dbf1ea7.jp g" alt="" />
Posted : 05/05/2014 2:45 pm
(@lowcountrysurveyor)
Have you tried FindAControl in the app store? I use it all the time on my iphone. There's and android version, too.
Posted : 05/05/2014 2:46 pm
(@ekillo)
No I have not, but I have been reading on here about it.
Posted : 05/05/2014 8:17 pm
(@ekillo)
Thanks, I will give that a try.
Posted : 05/05/2014 8:19 pm
(@ekillo)
Kevin you are right, it works just like you said.
Thanks
Posted : 06/05/2014 7:29 am
(@ekillo)
Loaded it and it works great.
Thanks
Posted : 06/05/2014 7:44 am
