free pdf to AutoCad converter
(@donwlenz)
Does anyone know if there is a free pdf to AutoCad converter out there?
The ones I've tried all require some kind of purchase.
thanks,
Don
Posted : January 21, 2013 1:13 pm
(@scott-mclain)
This one is good for 30 "free" uses.
http://anydwg.com/pdf-to-dwg.html
Posted : January 21, 2013 8:22 pm
(@artie-kay)
Don, I'll second Scott's recommendation. You won't get a total or perfect conversion every time, it depends on the content of the pdf. It's worth experimenting a bit with the output options too. I haven't found a better one.
Posted : January 22, 2013 1:14 am
(@eyott_surveyor_fred_md)
Don
you can use Inkscape it is open source.
all you have to do is open the PDF and save as DXF ( it takes about 10 minutes or so to run )
the down side is that all the line work ends up on one level but it scales almost perfectly.
Ref previous post:[msg=159244] https://surveyorconnect.com/index.php?mode=thread&id=159244#p159281 [/msg]
Posted : January 22, 2013 4:41 pm
