Fixed in SURVPC - Autonomous in Magnet
(@arctanx-2-2)
So I have an issue to where I can't get a fixed solution in magnet but I can using SURVPC.
I'm using GeoShack's Geonet. I'm using all the same credentials and IPs.
I connect to the server in both instances but magnet will not get a fix!
It's pretty frustrating.
My equipment vendor guys that help me out on this stuff have no idea what is wrong with my settings inside of magnet.
Posted : March 20, 2017 6:53 pm
(@stephen-ward)
arctan(x), post: 419418, member: 6795 wrote: So I have an issue to where I can't get a fixed solution in magnet but I can using SURVPC.
I know your issue is with Magnet, but I have trouble with SurvPC if I allow it to "connect to last bluetooth device" when I first open the job. Every time I let it do that I have to reset the connection between the DC and the GPS. Even disconnecting and reconnecting to the server will not fix the issue. Perhaps you've got something similar going on in Magnet.
Posted : March 21, 2017 2:52 pm
(@leegreen)
What type network is it?
What mount point?
Is your radio at 100%
Have you tried RTCM3 MSM?
Posted : March 21, 2017 4:22 pm
(@arctanx-2-2)
It's an ntrip network. The mount point is the same one I'm using in SURVPC. Radio is 100%. The server is sending and I'm receiving.
The mount point I'm using is using rtcm 3 but I'm not sure about the msm.
Posted : March 21, 2017 5:25 pm
(@terminus-nc)
Are you connecting to a mount point, but not the ntrip server? If so, there is a square button on the left hand side of the GPS connecting screen about half way down. Hit that and a pull down menu you will appear with IP address that magnet knows about within the instrument styles. There will usually only be one (the same one that appears to be already on the screen) and hit it. This happens to my magnets tablets all the time.
Posted : March 22, 2017 2:27 am
(@leegreen)
All networks are NTRIP. I meant is network Trimble, Leica or Topcon.
Do you have L2C turned on?
Interpolation or matched epoch?
Lot's of switches that may cause this.
Give ma call.
Posted : March 22, 2017 2:34 am
(@arctanx-2-2)
Here are pictures of my settings.
Geonet is a topcon network.
https://cpls.egnyte.com/fl/ThvFt5cMDX
Posted : March 22, 2017 9:50 am
(@arctanx-2-2)
I just wanted to let everyone know the [USER=2332]@leegreen[/USER] got me up and running with Magnet! He took the time out his day to help me out and not only did he fix my fixing issue he ran through all the settings and gave advice about the usage of them all.
I appreciate all the help, Lee!
Posted : March 22, 2017 6:07 pm
