Does anyone know how to directly export feature attributes in Trimble Business Center? I can not get the Shapefile or the DWG exporter to export attributes. I've set up a custom .csv file with an added column for attributes (as a temporary fix), then create the shapefile in ARCGIS. It would seem that if a software allows you to collect attributes, it should also allow you to export them without creating a work around.
Thanks
I seem to recall being able to do this.
Check out the links to the videos on the TBC Start Page.
I haven't used feature attributes, but this note is in the Survey Pro manual.
Note: Feature files are created using the Survey Attribute Manage included with TDS Survey Link, Version 7.2 or later.
I had used the same procedure using TBC 2.80 (and in previous versions) as shown in the You Tube videos and couldn't get the feature attributes exported to a shapefile. After upgrading to version 2.81 and trying it again, it miraculously worked. Thanks.
