Drawing a circle in Carlson survCE map
itchybees
(@itchybees)
Hello to the folks outstanding in their fields,
I am working with Carlson survCE V 4.07. I have been trying to draw a circle by using the DRAW / Circle in the map screen. I pick the point and the little command line says Circle -Rad /
I have tried many ways to then input my radius distance but to no avail. I can click on any other point and BLAM the circle appears based on the distance between the 2 points but I just can't get it to accept a radius and draw the damn circle.
Thank you anyone who can make me feel foolish by telling me the way to get this done. This is good software but it can be cumbersome in some functional use.
Bruce Archibald
Just south of Hudson Bay
Canada
Posted : May 6, 2016 2:49 pm
sergeant-schultz
(@sergeant-schultz)
I feel your pain. When you see -Rad/
type R at the cursor and Enter, you should then be able to enter the radius at the cursor
It took me 4ever to learn that when you see the / there're options that may require alpha input before you can make numeric input, i.e. telling it you want to input the radius (R, Enter) and not define the circle with 2 pts.
Posted : May 6, 2016 3:01 pm
itchybees
(@itchybees)
Sergeant Schultz, post: 370955, member: 315 wrote: I feel your pain. When you see -Rad/
HAHAHAHA! You know I thought I had done that but after so many attempts the right answer disappears sometimes doesn't it ?
Thanks so much for your prompt AND correct answer Sarge !!
Enjoy the life,
Bruce
Posted : May 6, 2016 3:11 pm
ken
 ken
(@ken)
I wish carlson had stronger arc-curve functionality in the map screen. Like being able to draw a tangent or non tangent arc from points or bearings. Like you can within carlson desktop software.
Posted : May 6, 2016 5:43 pm
back-chain
(@back-chain)
In the field> Hot as .
No bites at the calc,d location. Need to estimate a new search location and can't figure this #^*{ out. .
Phone out. Search terms entered. First line in query response:
Dun, dunnn, dunnnnnnnnn!!!!!
You guessed it> rplstoday ( specifically, this thread).
Come ahead. We're onto the next one.
Thanks to all involved!
Posted : July 26, 2017 7:32 pm
