Before I switched to Carlson 2011 from LDD 2007 when I issued a "copy" command, the AutoCAD program automatically assumed I wanted to do a "multiple" version, which I liked.
Is there some toggle I can switch to make it do that again?
Posted : September 22, 2011 6:21 am
Carlson uses the code "CO" for single copy. For multiple copy it uses "CP".
Carlson uses "C" for something like "chord" or whatever. To return you quick key functionality, IF you are in an AutoCad embedded version, you can copy the acad.pgp file and rename it "SURV.pgp" and put it in the "SUPPORT" directory. Just remember that the Carlson quick keys will take priority, so you may have to rename some of your favorite quick keys.
Posted : September 22, 2011 9:20 am
CP
Sweet, thanks man!!
Posted : September 22, 2011 9:31 am
