Civil 3D Baseline Interval Trick
(@surveyordave96)
Eminent Member Registered
Iƒ??m sure most of you know this function by now, however, Im putting this out there with the hopes someone might be out of the loop. It saved me at least a full day in the office so figured Iƒ??d post it on here. If you want a quick and simple way to create points at certain intervals along a baseline, follow the steps below.
4E5166AE 3F47 49FC A855 C6955B2CBC45
93917016 F14B 4B62 937F 236DF1E179FB
6F90156B 193B 4BE8 A734 2F933E3BF6B4
Posted : 24/06/2021 12:44 pm
Illustrious Member Registered
Is that like the DIVIDE command, but probably more powerful?
Posted : 24/06/2021 12:57 pm
(@lurker)
Prominent Member Registered
I feel sorry for the guy who has to stake that. That is so flat water will evaporate long before it ever flows.
Posted : 24/06/2021 1:13 pm
(@rover83)
Noble Member Registered
@brad-ott?ÿ
Closer to MEASURE than DIVIDE, but it's specifically for C3D alignments, can generate points left or right of the feature, and doesn't have to be a standard interval. I haven't used it in a while, but it is killer for generating points from ROW/road plansets. Especially if you can extract the station/offset text from the PDFs to drop into Excel...
Posted : 24/06/2021 1:17 pm
(@chris-bouffard)
I'm a Carlson SurvCad user and they have a routine in Cogo where you can interval along an entity and set your point stationing along the baseline.?ÿ I typically use 50' along the tangents and 25' stations along longer curves, draw my lines in my design drawing or an engineering drawing I reference in, in the direction I want the points to go, and let the software do the rest.?ÿ If you are staking curbing, or things of the like, you can create a centerline profile, input vertical curve info with PVC PVI and PVT, then offset the centerline and adjust it up for your curb reveal and you saved yourself a ton of work on larger jobs.?ÿ It will calculate hundreds of points in seconds.
?ÿ?ÿ
Posted : 24/06/2021 1:28 pm
(@jitterboogie)
Famed Member Customer
@lurker?ÿ
I had a project that flat last year.....huge PITA!
Posted : 24/06/2021 1:48 pm
(@surveyordave96)
@lurker haha I just put some random numbers in for visual purposes
Posted : 24/06/2021 2:03 pm
Share:
