Carlson2018 w/ Intellicad- hatch invisable in PS
7 Users
(@lanceboyle93101)
Reputable Member Registered
All hatching is visible in Modelspace, and plottable. Hatching not visible in paperspace and does not plot. If exploded, hatch is visible/plottable in PS.
Transparency is set to 'by layer', if that means anything.
Must be some check box somewhere but no can find. CS gurus ???
Posted : 10/02/2018 11:33 am
(@luke-j-crawford)
In layout tab, activate and lock the VP, try running the "pslts" command if it shows a 1, type 0, if 0 enter 1.
Just a shot?ÿ
Posted : 10/02/2018 2:42 pm
(@ps8182)
Is the drawing in state plane coordinates? I tried Carlson with Inellicad back in 2013 and had a lot of hatching and general drafting quirks with drawings, drawn in SPC's or "big coordinates" as Carlson referred to it. They said it had something to do with the large coordinates values causing issues within the drawing and that it would probably be taken care of with the release of Intellicad 8.0. I switched over to the OEM version and never looked back, so don't know if these issues were taken care of.
Posted : 10/02/2018 2:46 pm
New Member Guest
Is the layer ?ÿon turned OFF in Paper Space?<br/>Seems odd if you explode and it shows though <br/>Double click the viewport and open layer explorer and check the layer settings, On /off, print/no print. <br/>You can only see that from 'within' the viewport, not whilst in model space. Think I'm right there,?ÿ
Posted : 10/02/2018 3:27 pm
(@dan-dunn)
Reputable Member Customer
Most likely you have the layer frozen in the viewport.
While in Paper Space enter LA and the command prompt to start the IntelliCAD Explorer - Layers. Find the Layer you hatch is on and look for the column titled "Current Viewport".?ÿ Make sure the layer is set to visible.
The hatch is most likely displaying when you explode it because it is reverting to layer 0 which is visible in the current viewport.
Posted : 12/02/2018 7:56 am
(@snowshoes)
Eminent Member Registered
If you're still having the problem, you could try toggling the "Annotation Visibility" button on and off.?ÿ It's beside the snap/grid/ortho buttons.?ÿ?ÿ
Posted : 18/02/2018 8:45 pm
 vern
(@vern)
Noble Member Registered
Just a guess.
Maybe the hatch scale is not the same as the PS viewport scale. I mainly see this issue with annotative text but it could apply to hatches also.
Posted : 20/02/2018 7:30 am
(@lanceboyle93101)
I'm pleased to report Snowshoes had it.?ÿ Annotation Visibility. Who knew you'd want annotations invisible??ÿ Its on the button bar at lower right.
I knew it was not a layer visibility issue, because other objects on same later were visible/plottable in PS.
thanks for all the responses.
-DLB
Posted : 24/02/2018 12:52 pm
Share:
