Carlson w/ Intellicad Linetype issue
 Thad
(@thad)
There was a command that would make a "dashed" linetype keep its spacing even through short vertices. I have a polyline with many short verticies that I need "dashed" and it only shows "dashed" where there are long segments. If i recall correctly it was an on/off or 1/0 command.
I hope I am clear in what I am asking (it is clear in my head but that is not saying much).
Thanks,
Thad
Posted : July 30, 2013 7:29 pm
(@t-ray)
In autocad its pedit (polyline edit) then LT for linetype generation option then YES
Posted : July 30, 2013 7:55 pm
(@shawn-billings)
Bring up the properties box by picking the line and right clicking. The option is at the very bottom of the box or next to last.
Posted : July 31, 2013 3:32 am
(@ladd-nelson)
You might also examine the PLINEGEN variable. From the IntelliCAD on-line help:
>PLINEGEN
>Determines whether the linetype used around the vertices of a polyline are continuous or dashed. The default value (0) sets the linetype around the vertex to a dash. Setting the value to 1 changes the linetype to a continuous pattern around the vertex of the polyline.
>Type: Integer
>Saved: In the .dwg file
>Range: 0, 1
>Default: 0
Posted : July 31, 2013 9:11 am
