Carlson Survey Tree Survey - How to handle multiple trunk trees
5 Users
(@bow-tie-surveyor)
Does anyone know how to handle labeling multiple trunk trees using Carlson Survey 2016? It has the built-in tree survey function hard coded in where you can enter the tree code, trunk diameter, drip radius and tag number all separated by spaces, but it wants a single number for the trunk diameter. Has anyone delt with this?
Posted : June 12, 2016 2:46 am
(@christ-lambrecht)
No Carlson here hut we note them as trunksize x nr of trunks
For ex. 20x3
Or
15x2 + 20x4
Chr.
Posted : June 12, 2016 12:40 pm
(@ron-lang)
I had an arborist tell me they measure the tree size at 4' from the ground and count each trunk as an individual tree in cases of multiple trunks. How ever i must admit i still label double, triple and so on.
Posted : June 12, 2016 1:19 pm
 ken
(@ken)
I use the FTF tree function in carlson. No multi tree quick codes, I use the nearest code and put a note that it's a double, triple, etc as suggested above. It's pretty easy in carlson to just copy the symbol or make a note that it's a cluster. Another option is to make a special cluster symbol and add a code.
Posted : June 12, 2016 3:09 pm
(@rich)
For a double I put 2 little tree logos slightly overlapping. 3 for triple. 4 for quad.
Then I label each tree.
Ex. 12"Tree
Or
Twin
12,8"
Or
Triple
8,8,6"
Posted : June 17, 2016 3:12 am
