CARLSON SURVEY 2015 in AutoCad 2015 Leaders
(@ekillo)
I am making a transition from LDT and having a problem finding a leader that acts like the text leader in LDT. I have tried the multileader but it seems to require text and puts it at an East rotation. I used the LDT leader and pressed escape to end the routine without text. As a work around I have copying leaders from old LDT drawings til I can figure out how to do them in Carlson. Can someone point me in the right direction?
TIA
Ed Killough, NCPLS
Posted : 03/09/2015 6:49 am
(@randy-rain)
QUICK LEADER COMMAND QLEADER JUST HIT ESCAPE WHEN IT PROMPTS FOR TEXT (IF YOU DON'T EVER USE TEXT TYPE QLEADER AND S FOR SETTINGS AND SELECT THE "NONE" RADIO BUTTON) SETTINGS IS ALSO WHERE YOU CAN SPECIFY STRAIGHT OR SPLINE AND HOW MANY PI'S
Posted : 03/09/2015 7:44 am
(@ekillo)
Randy Rain, post: 334908, member: 35 wrote: QUICK LEADER COMMAND QLEADER JUST HIT ESCAPE WHEN IT PROMPTS FOR TEXT (IF YOU DON'T EVER USE TEXT TYPE QLEADER AND S FOR SETTINGS AND SELECT THE "NONE" RADIO BUTTON) SETTINGS IS ALSO WHERE YOU CAN SPECIFY STRAIGHT OR SPLINE AND HOW MANY PI'S
Thanks Randy.
I am accustomed to being able to draw the PI's as needed. I do occasionally use text, just like the option to draw the leader and escape the text.
Ed Killough, NCPLS
Posted : 03/09/2015 7:55 am
(@ekillo)
Randy,
I tried that and it worked for the leader but the it is not drawing an arrowhead. I tried changing the arrowhead size in dimensions but it did not make any difference in the Qleader. The text said I could point it to a custom block, I would like to be able to use the old LDT arrowhead if possible.
TIA
Ed Killough, NCPLS
Posted : 03/09/2015 8:22 am
(@randy-rain)
GO TO THE SETTINGS AND THE LEADER LINE & ARROW TAB PULL DOWN THE ARROWHEAD SELECTION AND CHOOSE CLOSED FILLED
Posted : 03/09/2015 8:40 am
(@ekillo)
Randy Rain, post: 334922, member: 35 wrote: GO TO THE SETTINGS AND THE LEADER LINE & ARROW TAB PULL DOWN THE ARROWHEAD SELECTION AND CHOOSE CLOSED FILLED
That is what it is set on now and it did not draw an arrowhead, I must need to set something else.
Ed
Posted : 03/09/2015 8:54 am
(@ekillo)
Randy thanks.
I had to play with the size to get it the way I like it. Good to go.
Ed
Posted : 03/09/2015 9:01 am
(@eric-williams)
Keep in mind Carlson drawing setup allows you to set a scale and paper size from the get go...your leaders, points and text can be set there quickly for the duration of the drawing.
Posted : 03/09/2015 9:58 am
(@ekillo)
Eric Williams, post: 334941, member: 10005 wrote: Keep in mind Carlson drawing setup allows you to set a scale and paper size from the get go...your leaders, points and text can be set there quickly for the duration of the drawing.
I am trying to remember that, in LDT I left the scale at 1:1 and set the paperspace viewport for plotting.
Ed
Posted : 03/09/2015 10:55 am
