Carlson Sewer Network Plan View Labels - Help Please
2 Users
stephen-ward
(@stephen-ward)
I'm using the Attribute Block setting to label my structures automatically as I create the structures. For some reason each label block is being inserted with a rotation of N84°24'E. No other labels or symbols are having this issue. I can insert the block with the insert command and it comes in correctly. I've checked the UCS and been through all the settings that I know to check.
This drawing was created with Carlson 2013 on AutoCAD 2013 and did not have this issue. I'm now running Carlson 2015 on AutoCAD 2015 and I don't know if this is a glitch or a setting that I just can't find.
Any ideas appreciated.
Posted : February 11, 2015 6:16 pm
mdriver
(@mdriver)
Is your line (pipe) direction the bearing you relayed in the post?
Maybe your label settings is set to align to the pipe run instead of plan view type rotation?
I bet it's a setting in the Carlson Settings Explorer.
That's where your automated settings are.
Poke around there. I wonder if the plan view settings are set to align to the centerline?
Posted : February 11, 2015 7:32 pm
stephen-ward
(@stephen-ward)
It turned out to be a weird quirk in the block I was using.
The block started out as a simple circle with a text attribute inside. I needed to show part of my drawing at a different scale so I made the block annotative so I could easily show it at different scales. The block worked great, but Carlson's Hydrology module hasn't been updated to handle annotative blocks. I ended up with huge circles with tiny text located hundreds of feet from the structures. I edited the block and made everything non-annotative and that's when the rotation showed up. There are 90+ structures in the drawing and it was updating the labels for all of them. All had the same N84°24'E rotation.
I finally fixed it by recreating the block from scratch. Apparently that got rid of the gremlin that was hiding in the block.
Posted : February 11, 2015 8:29 pm
