Software, CAD & Mapping
2
Posts
2
Users
0
Reactions
5
Views
Somehow, I am defaulted to Separate Layers. For the POINTS. I want it NOT on separate layers. This way, when I bring in GPS data, and I have shot a point multiple times, I can put the non used points, on a layer called HID, so I don't accidently get the wrong point, and add a gimp of a few hundredths.
It is just mis behaving.
Posted : 11/05/2016 5:52 am
Setting up some codes in Field to Finish would solve that problem. You could code a description, such as CHK, to put the points in the HID layer. If you use a / after the code, F2F will treat any text following as uncoded text, so a point with description CHK/SBND200 would go to the hidden layer, but tell you what it was you were checking.
Posted : 12/05/2016 6:11 am
