Carlson not drawing 3D Polyline E-S-BREAKLINES
2 Users
I do not know why the software is suddenly refusing to draw the appropriate 3D polylines on the E-S-BREAKLINEs layers per my field codes F2F settings?
Tech Support tried a PATCH.?ÿ That did not help.
Very strange, this worked fine about a week ago.
Suddenly it is not?
I went back to rerun a F2F project from a couple weeks ago that worked fine then, did not work todayƒ???
Posted : March 22, 2022 6:42 am
(@blitzkriegbob)
Not sure if this is the exact same problem you are seeing, but I posted this long ago.
https://surveyorconnect.com/community/software-cad-mapping/carlson-f2f-not-drawing-all-3d-polylines/
Posted : March 22, 2022 10:42 am
Thank you, Bob.?ÿ I think Tech Support is having me do Dent's trick next...
Posted : March 22, 2022 11:41 am
This fixed BOTH issues!?ÿ Even though I could not find this file:?ÿ -tmp.fld
Thank You!
Sent: Tuesday, March 22, 2022 3:29 PM
To: ott@mainstreetconsulting.com
Subject: Re: (Case 361528) not drawing 3D Polyline E-S-BREAKLINES
Brad,
For the F2F issue, please follow these steps:
1. Browse to the following folder
C:UsersYour User NameAppData*RoamingCarlson SoftwareCarlson2021ICAD10_X64USER
2. Rename the following files
(Ex: rename "test.ini" to "test-OLD.ini"):
-flg2fin.ini
-getfile.xml
-temp.txt
-tmp.fld
*If you can not see the AppData folder, in Windows File Explorer, click the View tab along the top and toggle ON the options for "File name extension" and "Hidden items".
Let me know if you still see this issue.
Posted : March 22, 2022 11:53 am
(@blitzkriegbob)
Dent still helping out from up above.?ÿ
Posted : March 22, 2022 12:32 pm
