How do you set display precision to degrees from degrees minutes seconds with respect to the label angle function in Carlson Survey ?
Annotate Defaults - under the Angle tab
okay I looked there and tried to change setting but it seemed not to take- Select Deg and 0?
Pull down Annotate-Label Angle
Command line should show 'Define angle by ..."
Select "O" for options
Check box beside "Decimal Degrees"
Then "Decimal Places" should become available to fill in.
Select 0 for degrees only
Annotation>Annotate Defaults>Angle>Deg.Min.Sec. and then select the precision.
You could also try, from the pull-down menu; Draw, Dimension Style, Modify, then on the Primary Units tab towards the bottom right on the Angular Formats section change the Unit Formats and Precision.
